Camera on the Oregon 700 Series
Both the Oregon® 750 and Oregon® 750t outdoor handhelds have a camera for taking pictures during your outdoor adventures.
Provided the Oregon handheld has a GPS signal, it will also geotag the picture with coordinates from where the picture was taken. This is helpful if you want to visit a certain visual attraction again in the future, such as a waterfall.1
For additional information on this feature, see - Frequently Asked Questions about Using the Built-in Camera Feature on an Outdoor Handheld
Note: The camera feature is not available on the Oregon 700 handheld.
Using the Camera
- From the app drawer, select Camera2
- Adjust the orientation, zoom and flash
- To change the orientation of the photo: turn the device horizontally or vertically
- To zoom in or out: use two fingers on the touchscreen (Using the Touchscreen)
- To turn on the flash: select
- Note: You can only select Auto to use the flash when the camera detects a low light scene
- Hold
to focus and hold the Oregon still
- A white frame appears on the screen. The device focuses on the object inside the frame. When the photo is in focus, the frame turns green
- Release
to take the photo
The photo should now be saved, you can view it in the Photo Viewer menu option on the Oregon handheld. You can also view and back up saved photos on the computer using BaseCamp™ software. For information, see Related.
1To navigate to the coordinates of a saved picture, select while viewing it from Photo Viewer then View Information > Go.
2If you do not see the Camera option, it is possible it was removed inadvertently from the app drawer. For how to add it back, click here.
