View Maps Purchased as a Download or Pre-programmed SD Card for an Overlander Device
Once the the map has been downloaded or SD card has been inserted into the Overlander® GPS navigator, first make sure that the maps are recognized and enabled.
To do This:
  1. Touch the Settings icon
  2. Touch Map & Vehicle
  3. Touch myMaps
This page lists the maps that the device is currently using. You should see the title of your mapping software on this page and it will display check marks next to mapping that is enabled. If the checkbox is empty, place a check in the box.
To View the Maps Without Searching for a Location:
  1. Touch Drive
  2. Touch the map to view the full map
  3. Zoom out to view a larger area by touching the minus (-) button
  4. Drag your finger across the screen to pan around the map
  5. Continue moving the map to the desired coverage area
  6. Touch on the plus (+) sign until you can see the street level detail
You will now be able to view the mapping covered by the purchased map.
Related
