Turning Bluetooth Pairing Mode on for a vivomove HR
If you need to pair a vivomove HR to a smartphone or tablet through the Garmin Connect app, you need to turn on the Bluetooth pairing mode on the device. Turning on pairing mode will trigger a Bluetooth beacon signal that the Garmin Connect app will look for. To enable pairing mode, follow these steps:
  1. Wake the device by double-tapping the screen.
  2. Press and hold the touchscreen to access the menu.
  3. Select Settings icon (gear).
  4. Select Phone with Bluetooth symbol.
  5. Swipe the screen and select Pair Now.
The vivomove HR will now be in Bluetooth pairing mode.
NOTE: You must pair the watch through the Garmin Connect app, and not directly to the phone through Bluetooth settings.
Related
