12x135MM Direct Drive Thru Axle Fitment
You will need to identify the type of axle included with your trainer. Review the following FAQ before choosing an option below: Which Type of Axle Do I Have on My Tacx Trainer?
NOTE: Most newly purchased Tacx direct drive trainers will be a Type 2 trainer. The exception would be a trainer that has sat on a shelf for an extended period of time.
Type 1 Trainer
Your bike is not compatible in this configuration and cannot be used with a type 1 direct drive Tacx trainer.
Type 2 Trainer
You will need to purchase the following to mount your bike to the trainer: Direct Drive Quick Release with Adapter Set.
Tacx Trainer Fitment Guide
