To Connect the Device to a Wi-Fi Network:
1. Plug the device into a power source
2. Touch Settings
- SXS Edition
- Overland Editions
3. Touch Wireless Networks
4. Select Wi-Fi to enable Wi-Fi technology if necessary
5. Select a network
6. Enter the password for the network and select Connect
The device should then connect to the network. The network will be added to the list of saved networks. The device will reconnect to this network automatically when it is within range.
To Check For and Install Both Software and Map Updates on this Device:
NOTE: Updates will not be available if the device is on the latest version.
1. Touch Settings
- SXS Edition
- Overland Editions
2. Touch Updates
3. Touch Access Wi-Fi Settings if prompted
4. Select a network
5. Enter the password for the network and select Connect
The device will check for available updates once connected to a Wi-Fi network. A prompt will appear to install them if any are found.
- iOverlander data will be listed as a map update.
NOTE: The device will be unusable until the updates complete.
