Multi-Camera Support in VIRB Edit
The multi-camera feature in VIRB Edit allows for easily alternating between clips recorded by two VIRB cameras at the same time. If there are multiple clips recorded at the same time, when adding the clips you will be prompted to enable multi-cam editing. Once this has been enabled, the option to toggle between clips can be found by clicking on the Editing tab on the left-hand side.
From the Editing tab the Audio Source and G-Metrix Source can be selected to choose which camera the audio or G-Metrix data will come from.
In the video timeline an icon of two cameras with a number will be displayed over the particular clips with multiple camera angles. The number will represent which view is selected for that particular section. The clip will need to be split for each time that you want the camera angle to change, and then the specific angle selected from the Editing tab.
