Está a visualizar um artigo que não está disponível no idioma atual selecionado. Pode escolher outro idioma abaixo.
How to Install Software Updates to a Garmin TT 15 Collar
The Garmin TT™ 15 Collar software should be kept up-to-date in order to take advantage of improvements and bug fixes. Updates are free, and easy to install. Software updates can be installed through Garmin WebUpdater.
Important: This product is NOT compatible with Mac OS. Please use Windows version of Webupdater to perform updates.
  • Before following the steps below, you must download and install Garmin WebUpdater
  • You can follow along by watching the video below.
To Update Your Garmin TT 15 with WebUpdater on Windows:
1.
Connect your Garmin device to the computer with the appropriate USB cable.
Note: Avoid using USB 3.0 ports when updating a collar.
2.
Launch WebUpdater
WebUpdater will be launched during the installation process. If you already had WebUpdater installed, launch WebUpdater.
Windows: Either double-click the WebUpdater shortcut on the desktop (if available), or search for WebUpdater in your Start menu.
3.Select the desired device from the drop-down menu or click Find Device if your device isn't listed. Click Next.
4.WebUpdater will display the available updates. Click Next through the following pages to review the software release notes, the software change history, and the license agreement.
5.Check the box to agree to the license agreement terms and then click Next to begin the update process.
6. Once the update starts, WebUpdater will display the current progress.
7.
After installing the main update file, WebUpdater will prompt you to check for any additional updates. Click Next.
8.
If additional updates are available click the checkbox next to the desired updates and click Next to install them. Once complete, click Finish
If no additional updates were found click Finish
Once complete, disconnect your device from the computer and power it on to make sure the software updates installed successfully.
