Está a visualizar um artigo que não está disponível no idioma atual selecionado. Pode escolher outro idioma abaixo.
SD Memory Card Compatibility for the Garmin Catalyst
The Garmin Catalyst requires a microSD card to record your drive.
SD Card specifications for Garmin Catalyst:
Minimum CapacityMaximum CapacityCard TypesSpeed Class
32GB256GBmicro SD, microSDHC, and microSDXCClass 10 (or higher) is required
The following microSD Memory cards are recommended for your device:
microSD cards not listed MAY work, but performance is not guaranteed.
  • 32 GB
    • Included microSD card
    • Samsung Pro 32 GB class 10
    • Samsung EVO UHS-I
    • SanDisk Ultra 32 GB class 10
    • Kingston HCI Class 10
  • 128 GB
    • SanDisk Ultra 128 GB Class 10
  • 256 GB
    • Samsung EVO Class 10
Additional information:
  • microSD cards can be purchased from many retailers
  • SD memory cards wear out after they are overwritten a large number of times
  • Your device detects memory card errors automatically and alerts you when it is time to format or replace your memory card
  • The Garmin Catalyst displays the following message when the memory card is the wrong format
    • “Card Must Be Formatted.” “Formatting the memory card will delete all videos, photos, and data on the card.”
  • The Garmin Catalyst displays the following message when the memory card is at the end of its life and becomes too slow
    • “Memory Card Too Slow.” “The memory card does not meet the recommended speed class. Use a memory card rated at speed class 10 or higher.”
To help extend the useful life of your SD card:
  • Back up saved footage and format the memory card at least once every 6 months
  • Use a memory card with a higher storage capacity
    • Higher-capacity memory cards are overwritten less frequently and will usually last longer
  • Use a high-quality memory card with a speed rating of class 10 or higher
  • Purchase your replacement memory card from a high-quality manufacturer and a reputable vendor
Relacionado
