Garmin® Marine Device Shows No Sonar Option or Depth Reading
If a Garmin® marine device with an attached sonar transducer shows no sonar option or depth readings, it could be impacted by one or more of the the following factors:
Cavitation, or air bubbles going across the transducer that interfere with sonar readings
This may be caused by boat speed, transducer placement, or water turbulence
Sonar transmission
If the sonar transmission is disabled, then the sonar transducer won't function or return depth (Enable 'Transmit' setting in the sonar menu to continue with operation of sonar)
Transducer condition
Fowling of the transducer or damage to the cable will cause sonar malfunction, including depth loss (See: How to Clean a Transducer and Acceptable Paint For Use on a Transducer)
Transducer connection
Corrosion to the connection at the sonar port of a chartplotter, sonar module, or sonar transducer cable will cause sonar malfunction and connection loss (Remove and check any sonar connections, including extension cables, for discoloration or resistance)
NOTE: Transducers connected to the marine device using the NMEA 0183 or NMEA 2000 networks will not show sonar images, but depending on the transducer features, they will display depth, speed, and/or temperature readings.
Before troubleshooting the device, restore sonar defaults:
Current chartplotters from the sonar screen select ... / Options > Sonar Setup > Installation > Restore Sonar Defaults
Striker series from the sonar screen select the Menu
Previous chartplotter models see the Owner's Manual for accessing the sonar reset option
Select the scenario below for troubleshooting steps:
Device's home screen does not display sonar options
Garmin marine devices will not display a sonar option on the home screen if it does not detect a connected transducer or sonar module.
Check that the chartplotter and transducer models support the type of sonar view missing, such as ClearVu™, SideVu™, or Panoptix™. Go to garmin.com to search for specifications.
Error messages
If the device displays the message Transmission disabled, see the owner's manual for steps to re-enable transmission
If the device displays the message Sonar Transducer Disconnected, there may be a connection problem between the transducer and marine device, powered mount, or sonar module
Troubleshooting transducer connection issues
Check that the transducer is securely connected. Use a locking collar (also known as a split connector) if present
Make sure the notch on the transducer cable and the transducer port is aligned when re-connecting
If there is no locking collar on the transducer cable, a split connector can be purchased from the device's accessories page on garmin.com
See Marine Cable Collar Installation for instructions to install the locking collar
If using a wire block adapter, check that the bare wire connections to the block are securely connected to the correct ports
Check for corrosion at all connection points:
The transducer cable connector head
The transducer port on the device or powered mount
The wire ends and wire block adapter if one is in use
Light corrosion can be cleaned using a brush and dielectric grease
Heavy corrosion may have extended into the cable, the device, or the powered mount itself, which will need to be replaced
It is recommended to use a weather cap to protect the transducer port when the transducer is disconnected
Replacement weather caps can be purchased from the device's accessories page on garmin.com
If using a transducer extension cable, use as few as possible to connect the transducer to the marine device
See Maximum Transducer Extension for more information
Check for any damage to the cable and for the appropriate gauge size
If using a 6-pin transducer that can measure water temperature, a failed temperature sensor may cause the device not to recognize the transducer
On Airmar thru-hull transducers with a fairing block, such as the B744V and B744VL, see Replacing the Temperature probe in a Transducer for information about purchasing a replacement temperature probe from Airmar
If the device displays the message Unsupported Transducer:
Follow the steps in Troubleshooting transducer connection issues above
Update Software: Garmin Marine Device Software Updates
Check for power-related issues
If the device does not recognize a Panoptix transducer, including LiveScope, see Panoptix Transducer not Recognized by Connected Chartplotter for troubleshooting steps
Other troubleshooting steps
If there are crimps or cuts in the transducer cable, the transducer may not be able to transmit information and will need to be replaced
If the transducer is connected to an external sonar module, see Troubleshooting Marine Sonar Modules for further steps
The transducer must be clear of any fouling or scratches to get a depth reading
See How to Clean a Transducer for more information
If using a transom-mounted or trolling motor-mounted transducer, power on the chartplotter, take the transducer out of the water, and listen for a ticking noise
If there is no ticking noise, the transducer is not connected or may have become defective
Do not allow the transducer to run for long periods while out of the water, which may damage the transducer
If another compatible transducer is available and known to work properly, temporarily connect that transducer to the device
If the device shows a sonar option and operates properly, replace the transducer
See garmin.com for a list of the device's compatible transducers
If no sonar option is shown, and if all other troubleshooting steps have been completed, contact Product Support.
Flashing or dashed depth readings
If the device displays a flashing depth reading, dashed lines (– –) in place of the depth reading, or no bottom return, the transducer is not able to determine the water depth. This could be caused one or more of the following:
High boat speeds create cavitation that may prevent the transducer from picking up a sonar reading
See Losing Depth Readings at High Speeds for more information
The transducer must be clear of any fouling or scratches in order to get a depth reading
Set the correct transducer frequency on the device:
Go to garmin.com and look up the transducer model, then the Specs section to see the correct frequency
See the device's owner's manual for steps to manually set the transducer frequency
Restore the sonar default settings on the marine device
Steps to restore sonar default settings
The device will restore settings on all sonar views to default.
To restore sonar default settings on a STRIKER device:
Open any sonar page on the STRIKER press, the Menu button > Sonar Setup > Restore Sonar Defaults - Select Yes
To Restore sonar default setting on current GPSMAP devices:
From any sonar page press, Options > Sonar Set up > Installation > Restore Sonar Defaults > Yes will reset the unit to factory settings
To restore sonar default settings on an ECHOMAP or Legacy GPSMAP device:
Open any sonar page on the ECHOMAP or GPSMAP press, Menu > Sonar Setup > Installation > Restore Sonar Defaults - Select Yes
Mounting-specific troubleshooting
Select a transducer mounting type for troubleshooting steps:
Transom-mounted transducers
The transducer must be submerged in at least 1/8 in. of water to get a depth reading
If the transducer is higher than this or comes out of the water when not on plane, mount it lower on the transom
If the transducer must be tested when the boat is out of the water, submerge the transducer in a bucket of water
The transducer must be level with the water's surface
Installing a transducer at an angle, regardless of the degree, will result in inaccurate depth readings and bottom returns
If using a boat with a stepped or V-shaped hull, mount the transducer on the lowest point on the hull
Transducers mounted above the lowest step may experience cavitation
Some boats may require a thru-hull transducer if the transom-mounted transducer experiences cavitation even on the lowest step
If using a pontoon boat, transom-mounted transducers will experience cavitation at lower speeds than most power boats
It is recommended to use a pole mount, a plate, or a thru-hull or in-hull transducer on a pontoon boat
Trolling motor-mounted transducers
If the marine device has a trolling motor-mounted transducer and shows a bottom reading but no fish or suspended targets, this may be caused by either transducer placement or noise from the trolling motor.
The transducer must be mounted correctly on the trolling motor. See the transducer's installation instructions for more information.
The following steps can help reduce trolling motor interference:
Connect the trolling motor to a separate battery from the Garmin marine device
Run the trolling motor and transducer cables in opposite directions
Use ferrite beads on the transducer cable
Check for any corrosion on the trolling motor wires
Connect the trolling motor to a water ground, a grounding plate, or a post on the battery
Check the fuse of the trolling motor if it has one
Blown fuses can create electrical interference even if the trolling motor is still able to operate
In-hull transducers
The transducer must be appropriate for the boat's deadrise and correctly mounted
Go to garmin.com to search for the transducer and find the maximum deadrise on its Specs page
The transducer must be mounted in a solid fiberglass hull
500 W in-hull transducers must be mounted in solid fiberglass hulls no more than 3/4 in. thick
1 kW transducers can be mounted in solid fiberglass hulls up to 1 in. thick
The transducer will not work with cored fiberglass hulls, hulls with air spaces, or any other hull material
The transducer must not be mounted over any strake or other parts of the hull that will create turbulence or cavitation
If the in-hull transducer is in a fluid tank, check that the fluid reservoir is full and does not have a leak
If possible, fill the fluid tank with marine-safe antifreeze, such as propylene glycol, to cool the transducer elements
Thru-hull transducers
If using a thru-hull pairing, check that the adapter cable is secure and has no visible damage
If necessary, replace the adapter cable
