Calibrating the Compass on the Geko 301
The electronic compass must be calibrated (away from metal objects) when you first use the Geko™ 301 outdoor handheld and after each time new batteries have been installed.
- Press the PAGE button to access the Menu Page.
- Press the UP or DOWN button to highlight 'calibrate' on-screen and press the OK button to display the Calibration menu.
- Highlight the 'Compass' option and then press the OK button.
- Slowly turn two full circles in the same direction while holding the device level.
NOTE: To keep level while rotating, it is recommended to place the Geko 301 handheld on a flat surface. - Press the OK button to activate the 'Start' button. The screen will prompt you to "Turn Slowly". Keep the unit level and begin to rotate. A 'Just Right' message will display when you are turning at the proper rate. If you turn it too slowly or too fast a "Too Slow" or "Too Fast" message will appear.
- When the "Calibration Successful" message appears, press the OK button to accep the calibration. If a "Calibration Failed" message appears, press the OK button to restart the calibration.
