Activating the Voice Command on a Compatible Automotive Device
Voice command can be activated on a device by saying the device's wakeup phrase. The default wakeup phrase is "Voice Command" but, can be changed to a word or phrase designated by the user.
To change the wakeup phrase:
- Touch Tools
- Touch Voice Command
- Touch Customize Phrase
- Type the word or phrase of your choice
- Touch Done
Once the wakeup phrase is designated, speak the phrase to activate voice command.
Tips for using voice command:
- Speak in a normal voice directly at the device
- Speak commands as they appear on the screen
- Respond to the voice prompts from the device as needed
- To reduce the number of accidental voice command wake-ups, increase the length of your wakeup phrase
- Try 3 or more syllables or multiple words
- Speak Exit to exit voice command
- If you press Mute Instructions the verbal replies from Voice Command will be muted
If the voice command is not working properly on your device, see Voice Command Isn't Working on an Automotive Device.
