Editing Check-In Contacts in the Earthmate App
Check-in messages are a convenient way to send messages to specific group of friends and family. There are three check-in messages to choose from:
  • Check mark I'm checking in, everything is okay.
  • Triangle I'm starting my trip.
  • Square I'm ending my trip.
You can customize the recipient list of your check-in messages, but you cannot customize what the check-in messages say. Check-in messages will include your location if available.
Editing Your Check-in Contacts
NOTE: To edit your check-in contacts, your phone must have Wi-Fi or mobile data available so the changes can be saved to your online account. It is best to edit check-in contacts before leaving on a trip. If your inReach® account was created prior to September 27th, 2022, you may instead see Presets. For details on editing Presets, see - Editing inReach Preset Messages on the Garmin Explore Website.
  1. Open the Earthmate® app.
  2. Ensure your compatible inReach device is powered on and paired with the Earthmate app.
  3. Select Three horizontal lines (Android™) or More (iPhone®/iPad®).
  4. Select Message Bubble Check-in Messages.
  5. Select Edit Check-in Contacts to customize the recipient list of your check-in messages:
  6. Select an option:
    • Touch the field next to To: to manually enter SMS numbers, email addresses, or inReach addresses. You can also start typing the name of a saved contact, then select the contact from the list of results.
      -OR-
    • Select Plus Symbol, then select a contact under YOUR PERSONAL CONTACTS to add contacts that are already saved to your inReach account, or select Phone Contacts to add contacts that are saved to your phone.
  7. Select SAVE.
Android is a trademark of Google LLC.
iPhone, iPad, and Apple are trademarks of Apple Inc., registered in the U.S. and other countries.
Related
