SD Memory Card Size for the Alpha XL
The Alpha® XL dog tracking navigator can use up to a 256 GB maximum microSD card of Class 10 or higher. The Alpha XL navigator uses the exFAT file system format.
Additional information to keep in mind:
  • A device may draw maps more slowly when using a card with a larger capacity if there are too many files and/or large files on the card.
  • A microSD card with at least 16 GB of space must be used when updating the maps on a device.
  • Garmin Express™ will only install a map update to a memory card if there is not enough space on the internal storage of the device.
    • Maps cannot be moved from the device to a memory card manually.
  • Instructions on where to insert the microSD card can be found in your Device's Owner's Manual.
  • microSD cards can be purchased from Garmin or other retailers.  Garmin offers the 16 GB microSD Class 10 Card with SD Adapter for purchase.
