Creating a Route Using a List of Waypoints on a Garmin® Marine Chartplotter
The ability to create a route using an existing list of waypoints is a feature that was added in a later version of the operating system of the device.
If the chartplotter is not up to date on software, see Related Content.
Once the device's internal operating system is up to date, follow the steps below to create the route using waypoints stored in the device:
Select Information or Nav Info from the Home screen
Select User Data
Skip this step if Nav Info was selected
Select Routes
Select New Route
Select Use Waypoint List
Select the desired waypoint to be the start of the route
Select Add Turn to start the new route using this waypoint
Continue to select waypoints and select Add Turn button to finish the route
Select Done when the route is complete
For additional information about operating the device, refer to the owner's manual.
