Using the Dog Tracking Widget on the Descent G1
The Descent™ G1 has the ability to view the dog tracking information from a compatible dog tracking handheld. To start, ensure your Descent G1 is up to date on the latest software.
Adding the Dog Tracking Widget
- Hold UP/MENU.
- Select Settings.
- Select Widgets.
- Select Add Widgets.
- Select DogTrack.
NOTE: To view a dog on the widget the dog collar needs to be turned on and actively tracking.
Troubleshooting the Dog Tracking Widget
If your watch is unable to find the signal from your dog tracking handheld, remove the pairing on the watch for it to refresh and start a new search.
- Scroll to the dog tracking widget.
- Press the Start/Stop button.
- Select Forget Transmitter.
NOTE: You will not see the Forget Transmitter option if the watch has never been paired to a handheld before or if you have already forgotten the handheld.
Troubleshooting Your Dog Tracking Handheld
Before you can view the dog list on a watch, the handheld needs to be set up. For your handheld to broadcast dog data to your compatible watch, the handheld and watch must be within 15 feet of each other. Select your dog tracking handheld model below for steps.NOTE: For best results, ensure any other broadcasting handhelds are powered off.
Still Unable to See the Dog Tracking Widget
If the above troubleshooting steps do not resolve your experience ensure your software is up to date on your watch or your Dog Tracking handheld:
Descent:
Dog Tracking Handheld:
- Installing Software Updates to the Alpha 100
- Installing Software Updates to the Alpha 200/200i
- Installing Software Updates to the Pro 550 Plus
- Installing Software Updates to the Astro 320
- Installing Software Updates to the Astro 430
- Installing Software Updates to the Astro 900
