Setting Up My Tread GPS Navigator to Track My Dogs
These steps will walk you through setting up your Garmin dog tracking handheld and the Tread® - Overland Edition, Tread® - SxS Edition, Tread® XL - Overland Edition GPS navigators, Arctic Cat G8 Display, or Kawasaki RIDGE 8" Tread Display so you can track your dogs on a larger screen.
Setting Up the Tread GPS Navigator and Dog Tracking Handheld
See the detailed video below for instructions.
These steps work with the Alpha® 10, Alpha 100, Alpha 200, Alpha 200 Plus, Alpha 300, Astro® 320, Astro 430, Astro 900, and PRO 550 Plus dog tracking handhelds along with the Tread - Overland Edition, Tread - SxS Edition, Tread XL - Overland Edition, Arctic Cat G8 Display, and Kawasaki RIDGE 8" Tread Display.
On the Tread Navigator
Select Apps.
Select Adventure
Select Dog Tracker
Troubleshooting Your Systems
Enable Broadcast or Remote View on your Dog Tracking Handheld
NOTE: Ensure other broadcasting devices are powered off.
Alpha® 100
Select Set Up.
Select Dogs.
Select Broadcast Dog Data.
Select Enable.
Alpha® 10
Select Set Up.
Select Remote View.
Select Status.
Alpha® 200, Alpha® 200 Plus, and Alpha® 300
Select Set Up.
Select System.
Toggle on Broadcast Dog Data.
Astro®
Select Set Up.
Select Dogs.
Select Enable.
Pro 550 Plus
The Pro 550 Plus uses ANT+ to share dog locations to your compatible outdoor watch and broadcast dog data by default. No other steps are required on the handheld. Ensure your handheld is up to date on the latest software.
Checking for Software Updates for your System
Software updates are released to help communicate between devices
