Lane Assist on Automotive Devices
Your device has the Lane Assist feature, which guides you to the correct lane for an approaching turn or exit, making unfamiliar intersections and exits easy to navigate. The Lane Assist feature can be found in the upper left corner of the screen, as seen below:
Lane Assist is offered in the following coverage areas of City Navigator NT maps, starting with version 2010.10. Lane assist is available whether the map is downloaded as a map update, or purchased separately and added to the device:
Although Lane Assist information will not be available for smaller roads, it will typically appear on major multi-lane roads, highways, and interstates.
