Setting a Collection to Sync Using the Garmin Explore App
The Garmin Explore™ app can be used to set certain collections to sync to specific devices in the app.
For more information on Collections, see - Garmin Explore Website Collections.
Creating Collections in the Garmin Explore App
Collections can be created directly in the Garmin Explore app.
  1. Open the Garmin Explore app on your mobile device.
  2. Select Bookmark Icon Saved.
  3. Select Plus Symbol New Collection.
  4. Enter a collection name.
  5. Select Plus Symbol in a Circle Add Items.
  6. Select the items to add to the collection, then select Done.
  7. Select Done to save the new collection.
  2. Select Watch and Handheld Icon Devices.
  3. Select the desired device.
  4. Select Sync Settings.
  5. Touch Sync Selection.
    • If prompted to select a primary collection, select the desired primary collection, then select Back Arrow (Android) or Save (iOS) when finished. Data in the primary collection is automatically set to sync to the device.
      NOTE: Collections containing over 100 waypoints, 20 routes, 5 tracks, or a track with over 10,000 points may be too large to sync with your device and are marked with a yellow warning icon.
      Select Primary Collection
      Selecting Primary Collection
  6.  Touch the desired collections to toggle them to sync.
    Toggle On Collection
    NOTE: Collections set to Garmin Explore App Toggle On are set to sync to the device. Collections set to Garmin Explore App Toggle Off are not set to sync to the device.
  7. Touch the back arrow when done.
The selected collections are now set to sync to the device. You will now need to sync your device.
For steps on how to sync the Garmin Explore app, see - Syncing the Garmin Explore App.
Related
