Improving Returns on Garmin Traditional, ClearVu, and SideVu Sonar
Notes:
• See Garmin Marine Device Shows No Sonar Option or Depth Reading for troubleshooting steps if there is no sonar option or depth reading.
• See Troubleshooting Poor Returns with Panoptix LiveScope for steps to resolve LiveScope sonar quality issues.
If the traditional sonar, ClearVü™ sonar, or SideVü™ sonar views show unclear images or fails to display targets on a Garmin chartplotter or fishfinder, they could be impacted by one or more of the following factors:
Cavitation, or air bubbles going across the transducer that interfere with sonar readings
This may be caused by boat speed, transducer placement, or water turbulence
Transducer condition
Transducer frequency
Trolling motor noise
Water clarity
Before troubleshooting the device, disable the zoom or bottom lock by selecting Menu > Zoom on a sonar page.
Sonar settings
Changing water conditions can have a significant impact on the clarity of a sonar reading or its ability to display targets of certain sizes. Some settings can be adjusted to compensate for this:
Sonar settings
Edge: highlights the the strongest signal from the bottom to help identify its hardness or softness
Gain: adjusts the transducer's sensitivity
Increase the gain in deep water and higher speeds
Reduce the gain in shallow water and slower speeds
If the sonar display fails to pick up all returns, increase the gain until it shows the returns, then reduce the gain to the preferred level to reduce noise
Interference: reduces the effects of interference from nearby sources of noise, such as a trolling motor
Use the lowest interference setting possible
If the highest interference setting does not resolve the issue, the transducer installation may need to be adjusted
Range: the specified depth of the water column shown on the sonar display
It is recommended to set the range to Automatic to allow the device to track the bottom
Surface noise: hides noise on the surface to reduce clutter on the sonar display
Time-varying gain (TVG): reduces surface noise and the appearance of returns to compensate for weak sonar signals in deeper water
Increased TVG will make the colors associated with fish targets and low-level noise appear more consistent in various depths
Ultra-scroll: controls the scrolling speed of the sonar readout
Ultra-scroll is not available on all devices
Some transducers give the option to change the frequency to get better returns in certain water conditions or for targets at certain depths:
The lower the frequency, the deeper the sonar's range
The higher the frequency, the clearer the image
Higher-frequency sonar readings can compensate for surface turbulence
See the device's owner's manual for steps to adjust sonar settings.
If necessary, the sonar settings on the marine device can be restored to their factory defaults.
Steps to restore sonar default settings
To restore sonar default settings on a STRIKER™ fishfinder:
From any sonar page Press the Menu button > Sonar Setup > Restore Sonar Defaults > Yes
To restore sonar default settings on an ECHOMAP™ chartplotter:
From the sonar screen select Menu > Sonar Setup > Installation > Restore Sonar Defaults > Yes
To restore sonar default settings on a GPSMAP® chartplotter:
From the sonar screen select Options > Sonar setup > Installation > Restore Sonar Defaults > Yes
The device will restore settings on all sonar views to default.
Transducer troubleshooting
Transducer placement can have an impact on the clarity of a sonar reading.
General troubleshooting:
High boat speeds create cavitation that may prevent the transducer from picking up a sonar reading
See Losing Depth Readings at High Speeds for more information
If there are crimps or cuts in the transducer cable, the transducer may not be able to transmit information and will need to be replaced
The transducer must be clear of any fouling or scratches to get a depth reading
See How to Clean a Transducer for more information
Mounting-specific troubleshooting
Select a transducer mounting type for troubleshooting steps:
Transom-mounted
The transducer must be level with the water's surface
Installing a transducer at an angle, regardless of the degree, will result in inaccurate depth readings and bottom returns
If using a boat with a stepped or V-shaped hull, mount the transducer on the lowest point on the hull
Transducers mounted above the lowest step may experience cavitation
Some boats may require a thru-hull transducer if the transom-mounted transducer experiences cavitation even on the lowest step
If using a pontoon boat, transom-mounted transducers will experience cavitation at lower speeds than most power boats
It is recommended to use a pole mount, a plate, or a thru-hull or in-hull transducer on a pontoon boat
Trolling motor-mounted
If the marine device has a trolling-motor transducer and shows a bottom reading but no fish or suspended targets, this may be caused by either transducer placement or noise from the trolling motor.
Transducer placement:
The transducer must be mounted correctly on the trolling motor
See the transducer's installation instructions for more information
If targets begin to appear when the trolling motor is turned off, adjust the transducer placement
Trolling motor interference:
The vibration of the trolling motor can create interference on sonar readings from trolling motor-mounted transducers. To test whether or not the problem is caused by trolling motor noise, run the boat at speed and turn up the sonar gain to 100%. See the device's owner's manual for steps to increase the gain. If targets begin to appear at 100% gain, trolling motor noise is the most likely cause of interference at normal gain levels.
The following steps can help reduce trolling motor interference:
Connect the trolling motor to a separate battery from the Garmin marine device
Run the trolling motor and transducer cables in opposite directions
Use ferrite beads on the transducer cable.
Check for any corrosion to the trolling motor wires
Connect the trolling motor to a water ground, a grounding plate, or a post on the battery
Check the fuse of the trolling motor if it has one
Blown fuses can create electrical interference even if the trolling motor is still able to operate
In-hull transducers
The transducer must be appropriate for the boat's deadrise and correctly mounted
Go to garmin.com to search for the transducer and find the maximum deadrise on its Specs page
The transducer must be mounted in a solid fiberglass hull
500 W in-hull transducers must be mounted in solid fiberglass hulls no more than 3/4 in. thick
1 kW transducers can be mounted in solid fiberglass hulls up to 1 in. thick
The transducer will not work with cored fiberglass hulls, hulls with air spaces, or any other hull material
The transducer must not be mounted over any strake or other parts of the hull that will create turbulence or cavitation
If the in-hull transducer is in a fluid tank, check that the fluid reservoir is full and does not have a leak
If possible, fill the fluid tank with marine-safe antifreeze, such as propylene glycol, to cool the transducer elements
Thru-hull transducers
If using a thru-hull pairing, check that the adapter cable is secure and has no visible damage
If necessary, replace the adapter cable
