How Do I Remove Third-Party Site Access From My Garmin Connect Account?
Garmin works with many third parties to provide information to their applications by giving you the ability to share data that is collected by your Garmin device and uploaded to your Garmin Connect™ account. To remove your previously granted consent from sharing this data, choose your platform below and follow the instructions.
NOTE: Workouts added to your Garmin Connect Calendar from a third-party will not be removed if you remove the third-party's access to your account. These workouts will need to be manually removed if so desired.
Garmin Connect App Instructions
Open the Garmin Connect app.
Select More (bottom right).
Select Settings.
Select Connected Apps.
Under CONNECTED APPS choose an app to be prompted to remove access.
Select Disconnect.
Acknowledge pop up message by selecting DISCONNECT.
Garmin Connect Web
From a web browser, sign into your Garmin Connect account.
Select Profile & Account from the top right corner:
From the drop down select Account Settings.
Select Account Information.
Under Connected Apps select Disconnect under the apps you wish to remove from Garmin Connect.
Acknowledge pop up message by selecting Disconnect.
