Creating, editing, or deleting custom avoidances on a dēzl™ 560 or nüvi® 2400 series device
Your device allows you to set up custom avoidances so that you can avoid specific areas and lengths of road. This feature is useful if you want to avoid certain streets because they are a problem to travel on, as well as avoiding certain areas where your vehicle may not have the capability to travel, or if you simply do not wish to travel in that particular area. A maximum of fifty (50) custom avoidances can be created.
Note: Custom road avoidances may have to be re-set after each map update. Custom area avoidances should remain accurate and intact.
To access custom avoidances:
- Touch Tools
- Touch Settings
- Touch Navigation
- Touch Automobile
- Touch nuRoute
- Touch Custom Avoidances
- Touch Add Avoid Area or Add Avoid Road
After selecting the desired type of custom avoidance, you'll be able to select the area or road that you want to avoid.
To edit or delete a custom avoidance:
- Access the Custom Avoidance menu
- Touch the Custom Avoidance you would like to edit or delete
- Touch the menu button that shows as three horizontal lines
- Select the desired action
- Rename will allow you to type a new name for the selected custom avoidance for easier identification
- Disable/Enable will turn the selected custom avoidance off or on without permanently deleting it
- Delete will permanently delete the selected avoidance
Repeat these steps as desired to edit or delete other custom avoidances.
