.apk Files on the Camper/RV 785
Your device is able to read .apk files, which are files that contain Android-based applications for use on Android-based mobile operating systems. Loading an app to an Android device using one of these files is commonly known as "sideloading".
Although your device is capable of sideloading .apk files, Garmin does not offer support on the location, installation, or troubleshooting of these files and applications. If you decide to sideload an .apk file, it may or may not work correctly on the device. Garmin does not offer any suggestions on where to find these files and suggests that you only obtain these from trusted sources.
If the device is not working properly after an .apk file has been sideloaded to it, a factory data reset of the device can be completed to remove the files. Performing a factory data reset will reset the device to factory default settings and delete any saved waypoints, downloaded apps, music, photos, videos, and other data. A factory data reset will also remove the vehicle profile information.
Before performing a factory data reset, some device data can be backed up to your computer by following the steps in the FAQ  Backing up, Restoring, or Transferring Saved Data on Garmin Automotive Devices. Note that this will only back up saved waypoints, trips, and custom points of interest. Other data, including recently found locations, will not be backed up.
To Perform a Factory Data Reset:
  1. Open the device's Settings menu
  2. Touch Device Reset
  3. Touch Factory data reset
  4. Touch Reset Device
  5. Touch Erase Everything
The device will restart and prompt you to set up the device again. Note that the device can take longer to start up for the first time after it has been reset in this fashion.
