Disabling and Enabling Map Layers on the GPSMAP 67 Series
The GPSMAP® 67 and GPSMAP® 67i allow you to select which map layers are displayed so you can easily enable or disable any installed satellite imagery, PLSS (Public Land Survey System), USGS Quads, etc.
Disabling other layers can help give a better view of the other mapping information. Depending on the zoom level the map is being viewed at, certain layers may appear to be hidden if multiple layers are enabled.
Disabling/Enabling Map Layers
- From the Map page, press MENU.
- Select Map Layers.
- Any available map layer will display. Select the desired layer to enable or disable it.
= Enabled
= Disabled
- Press QUIT to return to the Map page.
The map should now reflect the changes made.
