Turning Bluetooth Pairing Mode On For a vivomove Series Watch
To pair a vívomove series watch to a smartphone through the Garmin Connect™ app, the watch must be in Bluetooth pairing mode. This mode triggers a Bluetooth beacon signal that the app will look for. A brand new watch out of the box will automatically be in pairing mode when you turn it on for the first time.
If the watch was paired to a smartphone previously, you will first need to remove the watch from the Garmin Connect app and from the Bluetooth list on your smartphone. For help see: .
Select your watch model below to reveal the steps to enable pairing mode.
vívomove® 3, vívomove® 3S, or vívomove® Sport
  1. Double tap the watch lens near the 6 o'clock position to wake up the hidden display.
  2. Press and hold the screen to access the watch's menu screen.
    GIF vivomove Sport Bluetooth
  3. Swipe and select the Bluetooth phone icon vivomove 3 Bluetooth Menu icon.
    GIF vivomove Sport
  4. Swipe and select the same Bluetooth phone icon vivomove 3 Bluetooth Menu icon.
    GIF vivomove Sport
The watch will now be in Bluetooth pairing mode.
IMPORTANT: You must pair the watch through the Garmin Connect app and not directly to the phone's Bluetooth settings.
vívomove® Luxe and vívomove® Style
    GIF vivomove Luze
  3. Swipe and select Phone.
    GIF vivomove Luxe
  4. Swipe and select Pair Phone.
    GIF vivomove Luxe
vívomove® Trend
  1. Double tap the watch lens to wake up the hidden display.
  2. Press and hold the touchscreen to access the menu.
    GIF vivomove Trend
  3. Select the Gear icon icon.
    vivomove Trend GIF
  4. Swipe up and select Phone.
  5. Select Pair Phone.
    GIF vivomove Trend
The watch is now in pairing mode.
