Audio Files
Download useful audio files:
A specific calibration track is necessary for a successful calibration of any of the OEM integration DSP products. Select the product you need to calibrate from the list below to download the correct calibration track:
For setting the input sensitivity on an amplifier using our 9-step method, a sine wave test tone recorded at 0 dB reference level in the frequency range to be amplified is needed. Select the tone appropriate for your application from the list below to download the track:
When setting up and tuning the TwK™, VXi, or MVi amplifiers we recommend using a pink noise test track, which is a random noise filtered to have equal strength per octave across the standard listening spectrum (20 hz - 20 kHz). Pink noise is widely used for testing the frequency response of an audio system, and is especially useful when paired with an Real Time Analyzer or Fast Fourier Transform analyzer. Periodic pink noise, also included below, is the identical to stereo pink noise except its timed to allows for proper impulse response measurements with MAX Measurement Systems. A mono pink noise track is also provided below, which is useful for determining the behavior of a center channel in an up-mixed factory set up. It is also useful for testing whether an all-pass filter is being used in a stereo setup. As with stereo pink noise, it is also used for testing frequency response of individual channels. You can download pink noise tracks at the links:
Additionally, if you need a replacement FiX™ or CleanSweep Calibration CD that originally came with your integration processor, you can download the full disks at the links:
Related
