Preloaded Kenwood Maps Become Disabled After Removing an SD Card
When a microSD/SD card is removed from a Kenwood device that takes downloadable microSD/SD card updates, the maps will become disabled. This happens by design for the map update process. This can also happen when using the microSD/SD card to check for updates, or purchase a traffic subscription.
To Enable the Maps:
  1. Load the navigation menu
  2. Touch Settings
  3. Touch Map & Vehicle
  4. Touch myMaps
Within this section you can see all of the mapping loaded to the device. If there is no checkmark next to the map(s) listed, touch the box to add a check. This will enable the mapping on the device.
