How to Reset My Descent Mk2 Series Watch
Generally, Garmin does not recommend performing a reset on your watch, but there are some instances where resetting the watch may help.
  • To restore the watch to default factory settings.
  • The watch is in the wrong language.
  • The watch no longer responds, is stuck or frozen.
Forced Restart Steps
If your watch is frozen or not responding, a forced restart is recommended. This will not delete any of your user data.
  1. Hold the Watch with circle in top left cornerLIGHT button.
    NOTE: You may need to hold for up to 30 seconds.
  2. When the watch face goes blank, release Watch with circle in top left corner LIGHT.
  3. Press Watch with circle in top left corner LIGHT to turn the watch back on.
If the restart does not work, another method to reset the watch can be tried. Select the heading below for steps on the reset.
Other Resets
After performing one of the resets listed below, learned fitness values for advanced fitness metrics will be reset during this process including: VO2 max, Training Effect, and more. The watch will need to relearn this data after performing a reset. Some of the information will be restored once you sync with Garmin Connect if your watch supports Physio TrueUp.
NOTE: Not all fitness data can be synced through Physio TrueUp. To learn more about what watches support Physio TrueUp and what data can be synced, see What is Physio TrueUp?
If your watch is paired to your phone, you will need to pair the watch back to the phone after resetting. For help on pairing your watch to your phone, refer to your owner's manual
Reset Default Settings
This reset will return your watch to the original factory settings, and delete some information such as user profile, personal records, metrics, and some other data.
  1. Ensure the watch is powered off.
    • You may need to hold Watch with circle in top left corner LIGHT for up to 30 seconds to turn the watch off.
  2. Hold Watch with circle in top left corner LIGHT until the watch turns on.
  3. When Descent logo appears, press and hold Watch with circle in bottom right corner BACK.
  4. Release Watch with circle in bottom right corner BACK once the Reset default settings? message appears.
  5. Select Yes.
The reset is successful if the watch finishes powering up and goes through initial setup. Try the steps again if initial setup does not appear. Following the reset, place the watch outside with a clear view of the sky for a minimum of 20 minutes to acquire satellite data.
Delete Data and Reset Settings
This reset will clear all settings, user profile, records, activity history, Connect IQ content, and other data.
  1. Hold Watch with circle on middle left side MENU.
  2. Select or scroll to Settings.
  3. Select System.
  4. Select Reset.
  5. Select Delete Data and Reset Settings.
  6. If necessary, press Watch with circle in bottom left corner DOWN and select Continue.
  7. Select Yes to apply the reset.
Unprompted Reset
It is recommended to read the steps in full below before performing them.
  3. When Descent logo appears, press and hold Watch with circle in bottom left cornerDOWN, Watch with circle in top right corner START/STOP, and Watch with circle in bottom right corner BACK/LAP.
  4. After the first beep release Watch with circle in top right corner START/STOP.
  5. After the second beep release the remaining buttons.
Related
