How Do I Install the Garmin Foot Pod?
There are two ways in which the foot pod can be installed. The most common method is to install the foot pod to your shoelaces, but some shoes have a special pocket in the insole where a foot pod can be installed.
Installing the Foot Pod to Your Shoelaces:
Press the tab on the lace clip to lift and separate the Foot Pod from the lace clip.
Loosen your shoelaces slightly.
Thread the lace clip through two secure sections of your shoelaces, allowing enough room at the top to tie the shoelaces.
Tie your shoelaces securely to keep the Foot Pod from shifting during your workout.
Snap the Foot Pod into the lace clip. The arrow on the Foot Pod must be pointed toward the front of the shoe.
Installing the Foot Pod Under Your Insole:
NOTE: Your compatible shoe will have a pocket under the insole. You may need to remove the foam insert before installing the Foot Pod
Lift the insole of the shoe.
Place the Foot Pod in the pocket with the ANT+™ logo facing up and the notch pointing toward the front of the shoe.
