Using Map Manager on Forerunner Watches
The Garmin Forerunner® watches with the Map Manager feature allow you to add, update, or remove maps directly from the watch. To see if your watch is compatible search "Managing Maps" in your owner's manual. The process to access the Map Manager can vary by model.
When your watch is connected to a Wi-Fi® network, you can download available map updates or additional map regions. You can also remove maps to increase storage space on the watch. See the section below for Available Map Regions and Coverage .
The Garmin Express™ program can also be used to manage and download maps. For more information, see Related Content below.
NOTE: If your device includes preloaded golf maps (CourseView), the ski resorts map, or the U.S. public lands map they can be updated with the Map Manager, but not removed.
Using the Map Manager
Downloading maps over Wi-Fi can drain the battery, and download times can vary depending on the size of the map and your internet connection. The watch queues the map download and when you connect the watch to a power source, it will ask if you want to start the download.
The following directions should work for most watches. For specific instructions for your watch, see “Managing Maps” in your owner's manual.
  1. Hold UP/MENU (middle left button).
  2. Scroll to or select Gray gear icon Settings.
  3. Select Map or Map & Navigation.
  4. Select Map Manager.
  5. Select a map category.
  6. Proceed with the steps for adding, updating, cancelling an update or removing a map:
Adding a Map
NOTE: This option is mainly available for TopoActive maps and will only be presented if there are additional maps regions available to download.
  1. Select the desired map category
  2. Press START (upper right button).
  3. Select Add Map.
  4. Select the map.
  5. Select START (upper right button).
  6. Select Download.
The map download will ask to begin when your watch is plugged in to a power source.
Updating a Map
  1. Maps that can be updated will say "Update Available" next to them. Select the map you wish to update.
  3. Select Update.
Cancelling a Map Update
  1. Press START (upper right button) to select a map that has an update queued.
  2. Press START to remove the update.
The download will be removed from your download queue.
Removing a Map
NOTE: A Wi-Fi connection is not required to remove maps. Not all maps will have the option of being removed.
  1. Select the map you wish to remove.
  3. Select Remove.
The following TopoActive map regions are available to download using Map Manager.
Africa
Coverage for Africa is comprised of two different region files:
  • Light Green TopoActive Africa North: Includes Algeria, Benin, Burkina Faso, Cameroon, Cape Verde, Central African Republic, Ceuta, Chad, Côte d’Ivoire, Dijbouti, Eritrea, Egypt, Ethiopia, Gambia, Ghana, Guinea, Guinea-Bissau, Liberia, Libya, Mali, Mauritania, Melilla, Morocco, Niger, Nigeria, Senegal, Sierra Leone, Somalia, South Sudan, Sudan, Togo, and Tunisia.
  • Medium Green TopoActive Africa South: Includes Angola, Botswana, Burundi, Comoros, Democratic Republic of Congo, Equatorial Guinea, Gabon, Kenya, Lesotho, Madagascar, Malawi, Mauritius, Mayotte, Mozambique, Namibia, Republic of Congo, Réunion, Rwanda, São Tomé und Príncipe, Seychelles, Somalia, South Africa, South Sudan, Swaziland, Tanzania, Uganda, Zambia, Zimbabwe, Saint Helena, Ascension and Tristan da Cunha, and Bouvet Island.
TopoActive Africa Coverage
Americas North
Coverage for North America is comprised of three different region files: Canada and Alaska, United States (all U.S states except Alaska), and Middle America (South of the U.S. border).
TopoActive North America 2023.10
Antarctica
Green Areas Designating Coverage in Antarctica
Australia & New Zealand
China ML (Mainland)
TopoActive China ML Coverage
Europe
Coverage for Europe is comprised of three different region files:
  • Light Green TopoActive Western Europe: Includes Andorra, Belgium, Ceuta, Faroe Islands, France, Iceland, Luxembourg, Netherlands, Melilla, Portugal, Spain, and United Kingdom.
  • Medium Green TopoActive Central Europe: Includes Albania, Austria, Bosnia and Herzegovina, Croatia, Czechia, Denmark, Germany, Greece, Italy, Kosovo, Macedonia, Montenegro, Slovenia, and Switzerland.
  • Dark Green TopoActive Eastern Europe: Includes Armenia, Azerbaijan, Belarus, Bulgaria, Cyprus, Estonia, Finland, Georgia, Hungary, Russia (Kaliningrad), Latvia, Lithuania, Moldova, Norway, Poland, Romania, Slovakia, Sweden, Turkey, and Ukraine.
TopoActive Europe Coverage
Greenland
Blue Areas Designating Coverage in Greenland
Hong Kong & Macao
TopoActive Hong Kong and Macao Coverage
Japan
TopoActive Japan Coverage
Korea
TopoActive Korea Coverage
Middle East and Central Asia
Green Color Designating Coverage of the Middle East and Central Asia
SGMYVNPH (Singapore, Malaysia, Brunei, Vietnam, and Philippines)
TopoActive SGMYVNPH Coverage
South America
TopoActive South America 2023.10
Taiwan
TopoActive Taiwan Coverage
THID (Thailand and Indonesia)
TopoActive THID Coverage
