In the Garmin Golf app on your phone, touch the area highlighted in red to start making changes to the metrics displayed.
Swing Metrics Displayed in Driving Range Mode
The Driving Range mode in the Garmin Golf™ app allows you to practice on a virtual driving range, and provides detailed metrics for every shot recorded by your Approach® R10 portable golf launch monitor.
The metric data should be shared with a professional golf instructor for proper interpretation in order to improve your game.
Changing Swing Metrics
By default, Total Distance, Carry Distance, and Total Deviation Distance will be displayed at the top of Garmin Golf app. You can change the swing metrics that are displayed by touching the swing metric fields and picking a new metric to display there.
See the example below:
Viewing Types of Metrics and Their Descriptions
You can view a description of what each metric data field means by pressing and holding on a specific metric.
Open the Garmin Golf app.
Select
Select Practice.
Select Start Training.
Select one of the Practice ranges.
Select Start Session.
Press and Hold one of the three data fields at the top of the screen to view a description of the data field.
NOTE: To change a swing metric data field, select a swing metric field, you can choose to have any of the following metrics displayed.
Apex Height
Attack Angle
Backspin
Ball Speed
Carry Deviation Angle
Carry Deviation Distance
Carry Distance
Club Face
Club Path
Club Speed
Face to Path
Launch Angle
Launch Direction
Sidespin
Smash Factor
Spin Axis
Spin Rate
Total Deviation Angle
Total Distance
Examples of Metrics Displayed in the Golf App
Below are some examples of the metrics and screens you will see in the Garmin Golf app when in Driving Range Mode.
Enabling Spoken Audio Metrics
You can receive individual metrics audibly after each shot.
In a driving range session, select
Select the metric you want to hear.
NOTE: Only one audible metric can be played at a time.
The selected metric will now play after each shot depending on your phone's audio settings or, if it is paired, with a separate Bluetooth audio player.
