Hardwiring a Garmin Dash Cam Directly to a 12-Volt Power Source
It is not recommended to hardwire Garmin automotive products to a 12-volt power source unless using a specifically-designed, Garmin-made accessory with a compatible device. Hardwiring a device in any other way may cause damage. Damage incurred in this way is not covered under warranty.
- Garmin Dash Cam devices can be powered by a Constant Power Cable accessory that provides power from your vehicle's OBD-II port. This cable is easily self-installed.
- These Garmin Dash Cam devices can also be powered by a Parking Mode Cable with USB-C connector accessory which hardwires the dash cam to a power source. Garmin strongly recommends having the Parking Mode cable professionally installed.
- Garmin Dash Cam™ Mini 3, Garmin Dash Cam™ X110, Garmin Dash Cam™ X210, and Garmin Dash Cam™ X310 see Using the Parking Guard Feature on a Garmin Dash Cam.
These Garmin Dash Cam devices can be powered by a Parking Mode Cable with microUSB connector accessory which hardwires the dash cam to a power source. Garmin strongly recommends having the Parking Mode cable professionally installed.
Garmin Dash Cam™ 46, Garmin Dash Cam™ 47, Garmin Dash Cam™ 56, Garmin Dash Cam™ 57, Garmin Dash Cam™ 66W, Garmin Dash Cam™ 67W, Garmin Dash Cam™ Live, Garmin Dash Cam™ Mini, and Garmin Dash Cam™ Mini 2 see Using the Parking Guard Feature on a Garmin Dash Cam.
- Garmin Dash Cam™ 45, Garmin Dash Cam™ 54, Garmin Dash Cam™ 55, and Garmin Dash Cam™ 65W, see Parking Mode on a Compatible Garmin Dash Cam.
Concerns of using other power cables (outside of getting enough power) is that the cable may not be capable of providing a clean power signal to the device. This could affect the overall performance for all features to work.
When hard-wiring a device to a vehicle's battery, the dash cam may constantly be drawing and draining power from the vehicle.
If a device is not covered by the options above, it should never be hardwired under any circumstances.
