Change Currency on ecoRoute
If you need to change the type of currency displayed in ecoRoute, it will be necessary to change the Locale of your device to the appropriate location. To change the Locale, you must restore the settings on the device to factory default values. This will not remove any map and software updates or saved locations.
To restore the default settings:
  1. Touch Tools
    • Some devices skip this step
  2. Touch Settings
  3. Touch Restore
    • Some devices require pressing the menu button (three bars in the upper-left)
  4. Touch Yes
  5. Select the correct Locale
Once you have reset the Locale, ecoRoute will default to the appropriate currency of the chosen Locale.
