User Data Limitations of the Rino 600 Series
When sending or creating files for a Rino® 600 series handheld, keep in mind the following limitations:
2,000 GPX files
2,000 waypoints
5,000 geocaches
200 routes, 250 points per route; 50 points turn-by-turn routing
200 saved tracks
2,000 archive tracks1
10,000 points per track
100 custom map tiles
50 contacts with 2,000 track points each
250 BirdsEye Imagery files
Approximately 3,000 mapping segments2
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on the device.
When utilizing routes, only 50 points can be used for turn-by-turn navigation on roads or trails.
1 Archive tracks do not count against GPX file limit; 1 archive track per gpx file.
2 See Related for more information on map segments.
