Activating SiriusXM Weather and SiriusXM Radio Service
To use SiriusXM on a Garmin chartplotter, a compatible weather antenna will need to be connected to the device. Refer to the owner's Manual for the chartplotter to determine which SiriusXM antenna is required.
SiriusXM weather and radio are subscription-based services through the provider, SiriusXM. To activate a subscription, use one of the following methods:
Before contacting SiriusXM, the Weather ID and Radio ID of the weather antenna will need to be determined. These numbers can be found on the bottom of the antenna. These numbers can also be found in the menu of the chartplotter or sounder the antenna is connected to. The Weather/Radio ID can be found on the Software Information Page of the device. Refer to the Owner's Manual for information on where to find the Software Information Page .
If a GDL® 30A receiver is being used, there will be a Weather ID and a Radio ID that are different. If a GXM™ 30 antenna | GXM™ 40 antenna | GXM™ 51 antenna | GXM™ 52 antenna | GXM™ 53 antenna | GXM™ 54 antenna is being used, there will only be one ID that is used for both Weather and Radio.
