Instructions for Completing ICAO Format FAA Flight Plan Form 7233-4
This document provides basic instructions for filling out the International Civil Aviation Organization’s (ICAO) formatted flight plan form, FAA Form 7233-4. Notice that the upper portion of the ICAO format flight plan is not to be filled out by the submitter, as this is for FAA use only. You will also see that there are numbers in front of some fields, and not in front of others. These numbers correlate with system numbers used by the FAA, and are referenced in AIM guidance. You will begin with entry field 7, Aircraft Identification.
Explanations for entries you will need to make in each of the fields are shown below. Where a more detailed explanation is needed, a link is provided to a reference document. When filling out this form, be sure to use CAPITAL LETTERS only.
BASIC INSTRUCTIONS
FIELD TITLEENTRY (or reference)EXPLANATION
AIRCRAFT IDENTIFICATION(e.g. N814LW)
N-Number of ICAO telephony designator of agency followed by flight identification
(e.g. CAP2142)
FLIGHT RULES
IFlights to be conducted entirely under IFR conditions.
VFlights to be conducted entirely under VFR conditions.
YFlights that commence under IFR conditions and change to VFR conditions.
ZFlights that commence under VFR conditions and change to IFR conditions.
TYPE OF FLIGHT
SScheduled air transport
NNon-scheduled air transport.
GGeneral aviation flight.
MMilitary flight.
XAll other types of flights.
NUMBER(e.g. 03)2-digit number of aircraft in flight, only required for formation flights.
TYPE OF AIRCRAFT(e.g. SF50)4- character ICAO aircraft type code. If none issued, enter ZZZZ in filed, and TYP/MODEL NAME in Field 18.
WAKE TURBULENCE CAT.LMax. certified takeoff weight of 15,500 lbs. or less.
MMax. certified takeoff weight <300k lbs. & >15.5k lbs.
HMax. certified takeoff weight of 300,000 lbs. or more.
EQUIPMENT
(FIELD 10a/10b)
AIM
(PAGE 5-1-21)
This field has two parts, 10a and 10b. Field 10a concerns the type of Communication and Navigation equipment installed. Field 10a has numerous possible codes.
AIM
(PAGE 5-1-22)
Field 10b concerns the type of Surveillance equipment installed. Field 10b has numerous possible codes.
DEPARTURE AERODROME(e.g. KFCM)4- character ICAO airport code. If no ICAO designator, enter ZZZZ and put DEP/CODE (e.g. 2S7) in Field 18.
TIME(e.g. 1645)4-digit UTC planned time of departure
CRUSING SPEED
(e.g. N0300) or
(e.g. M053)
True airspeed in knots entered as “N” followed by 4 digits, or Mach cruise entered as “M” followed by 3 digits.
LEVEL
(e.g. F280) or
(e.g. A070)
Cruising altitude in Flight Level entered as “F” followed by 3 digits, or in Altitude entered as “A” followed by 3 digits.
ROUTE
(e.g. GEP J70 ABR) or
(e.g. DCT)
The route intended to be flown. Airways require entry and exit points. DCT is entered for Direct.
DESTINATION AERODROME(e.g. KFCM)4-charachter ICAO airport code. If no ICAO designator, enter ZZZZ and put 2ND DEST/CODE (e.g. 2S7) in Field 18.
TOTAL EET(e.g. 0430)Estimated en route time with 4-digits
ALTN AERODROME(e.g. KFCM)4-charachter ICAO airport code. If no ICAO designator, enter ZZZZ and put 2ND ALTN/CODE (e.g. 2S7) in Field 18.
2ND ALTN AERODROME(e.g. KFCM)4-charachter ICAO airport code. If no ICAO designator, enter ZZZZ and put 2ND ALTN/CODE (e.g. 2S7) in Field 18.
OTHER INFORMATION
(FIELD 18)
PPN/See the FAQ concerning ICAO PBN/RNAV-RNP for codes to follow the “/”.
See the FAQ concerning ICAO PBN/RNAV-RNPNumerous other entries available.  See table for required and common entries for this field.
ENDURANCE(e.g. 0530)Total fuel endurance in hours and minutes.
PERSONS ON BOARD(e.g. 005)Number of persons onboard using 3-digits.
EMERGENCY RADIOXEnter an "X" if the equipment is NOT aboard.
SURVIAL EQUIPMENTS and XEnter S if survival equipment is available, and then place an "X" in the type of equipment NOT available.
JACKETSJ and XEnter J if life jackets are available, and then place an "X" in the features NOT part of the jackets.
DINGHIESXEnter X's if NO life raft is available. If a dinghie is available, use 2-digits to indicate number, 3-digits to indicate capacity of all dinghies aboard, and enter an "X" if the dinghies are covered.
AIRCRAFT COLOR AND MARKINGSAlpha charactersDescribe the colors and markings of the aircraft to aid in Search and Rescue operations.
COLOR(e.g. ORANGE)Enter the color of the dinghies.
REMARKSAlphanumeric
X out the "N" box if no remarks are entered.
This field is for remarking about additional survival equipment or features.
PILOT-IN-COMMANDAlpha charactersEnter the First and Last Name of the PIC
The attached document below provides tables that describe the equipment capabilities for each Garmin® system. (Garmin Performance-Based Navigation Capabilities)
Related
