Navigational Avoidances on Garmin Automotive Devices
Garmin devices have an Avoidance menu where you can select various options that will adjust how your device routes you. Items with a checkmark beside them will be avoided whenever possible.
To Locate the Avoidance Menu:
- Open the device's Settings menu
- Touch Navigation
- Touch Avoidances
- Touch the desired Avoidance to enable it
Repeat the steps above to disable the checked Avoidance.
Available Avoidances:
- U-Turns – Avoids calculating routes that require a U-turn.
- Highways/Major Highways – Avoids highways, interstates, freeways, motorways, and other major routes.
- Toll Roads/Tolls and Fees – Avoids toll roads and certain specified congestion zones.
- Ferries – Avoids routes that require a ferry crossing.
- Carpool Lanes – Avoids lanes designated specifically for carpooling sometimes referred to as High-occupancy vehicle (HOV) lanes.
- Paved Roads & Trails – Avoids paved roads and trails.
The following avoidances are available elsewhere in the Navigation menu:
- Custom Avoidances – Feature available on some devices that will allow you to select specific areas or lengths of road to avoid
- For more information about custom avoidances and steps to set them up, refer to your device's owners' manual.
- Custom road avoidances may need to be re-set after each map update, but they should remain intact and accurate after map updates.
- Environmental Zones – Avoids areas with certain travel restrictions
- More information about Environmental Zones can be found in the following FAQ: Environmental Zones.
NOTE: Devices will only avoid selected items when it is possible. For example, if you have U-turns selected as an avoidance, but there is not an alternate route available that excludes U-turns, the device may still direct you to make a U-turn.
For more information about custom avoidances and steps to set them up, refer to your device's owners' manual. Custom road avoidances may need to be re-set after each map update, but they should remain intact and accurate after map updates.
