Pairing an inReach SE+ or Explorer+ With a Phone or Tablet and Activating a Subscription
Your inReach® handheld can be paired with a mobile device and the Earthmate® app to write, send, and receive messages using the interface of your mobile phone or tablet. Follow the instructions below to pair an inReach SE®+ or inReach Explorer®+ to a mobile device. If an inReach satellite subscription has not yet been activated for the device, the Earthmate app will also allow you to activate a subscription.
If you are pairing a device that is not your original device, you may see the following error:
Warning Regarding Deleted Data
This message is referencing the data on the device, rather than the account data in the Earthmate app. The replacement device is syncing with the account for the first time, therefore, data on the device can be overwritten by account data syncing over. When this pairing is complete, some data may stay on the device, while other data may get overwritten by the account's data.
If you are concerned about losing data we recommend verifying if the data appears on the map tab on your account at explore.garmin.com. If the data is not showing, your original device would need to be synced before transferring service to a different device and pairing it to Earthmate. For steps, see - Updating inReach Firmware and Syncing Account Changes with inReach Sync.
Pairing and Activating
NOTE: If you are pairing a new device, proceed with the steps below. If you have a device that was acquired second-hand, it may need to be reset before proceeding with these steps. To reset the device, see - Performing a Factory Reset on an inReach SE+ or inReach Explorer+
1. Setting up the Earthmate App
  1. Install and open the Earthmate® app.
  2. Tap Next.
  3. Tap Next after reading and agreeing to the EULA.
  4. Select Create Account, then enter your name, email, and a password and select Next.
    • NOTE: If you already have a Garmin account or have previously used other Garmin apps such as Garmin Connect™ or Garmin Explore™ you can select Sign In (or Continue as ['username'], if prompted).
  5. Follow the prompts for maps and cloud storage:
    • To download maps tap Download or Not Now to skip. Maps can be downloaded at a later time, see - Downloading and Managing Maps With the Earthmate App.
    • To enable cloud storage tap Enable Cloud Storage or Not Now to skip. This setting can be adjusted later by selecting Three horizontal lines (Android™) or More (iPhone®/iPad®), then Account and SyncData and Privacy > Cloud Storage.
2. Pairing the inReach Device
  1. On the inReach® device, select Skip if you are prompted to activate.
  2. On the inReach device, select Settings.
  3. Select Bluetooth.
  4. Select Pair Device.
  5. Select Pair Device again.
    • NOTE: If previously paired, select Pair Again instead.
  6. In the Earthmate app, touch Handheld Device and Bluetooth Symbol from the top of the Map page.
  7. Select your inReach model.
  8. Touch Connect.
  9. Touch the inReach device once it appears in the list under Select An Accessory or Available Devices.
    NOTE: It may take 1-2 minutes for the device to appear in the list.
  10. Follow the prompts on your mobile device to enable permissions and finish pairing.
If an inReach plan has not yet been activated, continue with the steps below to activate. If an inReach plan was already activated previously, you will not be prompted to activate and the inReach device will be ready to use with the app.
3. Activating an inReach Plan
NOTE: Payment information needs to be provided in order to complete the activation steps below.
  1. After completing the steps above for pairing, if necessary select Three horizontal lines (Android) or More (iPhone/iPad), then My inReach > Activate.
  2. If prompted, sign in again.
  3. Choose between inReach Enabled, inReach Essential, inReach Standard, and inReach Premium plans.
    Tap Select This Plan for the chosen plan.
  4. SOS step:
    • Read through the included SOS benefits, then click Next.
    • If desired, choose Add for one of the Search and Rescue (SAR) insurance plans. This is not required. SAR insurance plans are available for purchase in the US, Canada, and US Territories (American Samoa, Guam, Northern Mariana Islands, Puerto Rico, US Virgin Islands). Once finished, select Next or Skip.
  5. Select the box to agree to automatic renewal, enter the names of the insured individual and beneficiary if SAR was added, then select Next.
  6. Review the terms and conditions, then select Accept & Continue.
  7. Enter your billing information, then select Next.
  8. Enter your emergency information (or select the box for Same as Billing Info), then select Next.
    • Emergency Notes is a good place to add information of any known medical concerns. If you have additional coverage for medical evacuation or search and rescue, you can include that and how to get in contact with the company providing that service. Example:
      SOS Contact and Information for Medical Evacuation Coverage
  9. Add Emergency contacts information, then select Next.
  10. Review all entered information to confirm it is correct, then enter your payment information.
  11. Check the box to authorize use of this payment method for future account charges, then select Complete Activation or Confirm Purchase.
  12. Once the activation is processing you can select Close.
    Processing Your Purchase
After completing the steps in the app, take the inReach device outside, ensure that it has a clear view of the sky, then follow the prompts on the inReach device to complete the activation. If this was skipped on the handheld previously, select Activation from the home screen, then proceed through the prompts until the device displays Sending Activation and wait for the activation to complete.
Related
