Navigational Avoidances on Garmin Automotive Devices
Garmin devices have an Avoidance menu where you can select various options that will adjust how your device routes you. Items with a checkmark beside them will be avoided whenever possible.
NOTE: Custom road avoidances may need to be re-set after each map update. Custom area avoidances should remain accurate and intact after updating maps on the device.
A Detailed Video Tutorial Discussing Route Settings is Available Below:
To Locate the Avoidance Menu:
- Touch Tools
- Touch Settings
- Touch Navigation
- On the dēzl™ 560, touch the desired driver profile (Automobile, Truck, RV, Pedestrian) then nuRoute
- Touch Avoidances
- Touch the desired Avoidance to enable it
Repeat the steps above to disable the checked Avoidance.
Available Avoidances:
- U-Turns – The U-Turns avoidance will avoid taking you on a route that requires a U-turn
- Highways or Motorways – The Highways or Motorways avoidance will avoid highways, interstates, freeways, motorways, and other major routes
- Toll Roads or Tolls and Fees – The Toll Roads or Tolls and Fees avoidance will avoid toll roads and certain specified congestion zones
- Traffic – The Traffic avoidance will route you around traffic problems if a quicker route is available, provided you are using a traffic receiver with an active traffic subscription
- Disabling the traffic avoidance does not disable traffic alerts from appearing on the device; however, it will not take the reported traffic incident into account when calculating routes
- Ferries – The Ferries avoidance will avoid taking you on a route that requires a ferry crossing
- Carpool Lanes or Car Share Lanes – Avoids lanes designated specifically for carpooling sometimes referred to as High-occupancy vehicle (HOV) lanes
- Unpaved Roads – The Unpaved Roads avoidance will avoid taking you on unpaved roads
- Custom Avoidances – Custom Avoidances is a feature available on some devices that will allow you to select specific areas or lengths of road to avoid
Note that devices will only avoid selected items when it is possible. For example, if you have U-Turns selected as an avoidance the device may still direct you to make a U-Turn if an alternate route is not available.
