Troubleshooting Interference on the Pro 550 Plus
The Pro 550 Plus gives you the options to change your dog's ID number.
Changing the Dog ID Number
On the handheld:
  1. Switch your toggle to the desired dog (black, red, blue).
  2. Turn the dial to N.
  3. Select the Tone button.
  4. Use the training keys to scroll through to find Change ID.
  5. Use the Tone button to select Change ID.
  6. Select the new frequency and channel you want the dog collar on.
Note: If you change a dog's ID and the dog is already paired to another handheld you will need to change the ID on that handheld as well.
Hunting With or Near other Hunters
Interference can happen when you are hunting around other hunters or hunting in groups. The best way to avoid this is ensuring that you all have your collars set to different channel numbers. Collars are automatically allocated ID numbers on open frequencies and channels when being added to the handheld. If you are unable to be on different channel numbers make sure there is ample distance between hunters on similar channels, distance can help prevent conflict and collars dropping signal while out in the field.
