Press the middle right button once
Press and hold the lower right button
Select Shortcut settings
Select the function you want
Setting up the Right Middle Shortcut Button
The middle button on the following watches serves two functions depending on if you short press or long press the button:
Venu® 2 Plus
Venu® 3 | Venu® 3S
D2™ Air X10
Long Press Middle Button
A long press activates the voice assistant feature on the watch. To learn more see: Setting Up Voice Assistant on Your Garmin Watch.
Short Press Middle Button
A short press of the button can be set to control one of the following functions:
Music Controls
Save Location
Alarms
Stopwatch
Timer
Brightness
Wallet
Voice Assistant
Phone Calling
Dial Pad
Contacts
Volume
Setting up Shortcut Control the First Time
Follow the steps below to set up this feature on your watch.
Swipe up
Select Setup
Select the function you would like for the button
Selecting "Disable" will disable the single press function
Changing the Shortcut Control Setting
Select your watch and follow the steps if you have previously set up this feature and want to change what the button controls.
Select Settings
Select Shortcut
I Previously Disabled the Shortcut Control Feature
If you selected Disable you can reenable the button by following these steps (you can also swap the functions of the buttons in the following menu):
From the clock face, press and hold the lower right button
Scroll to and select Settings or
Select Shortcut
Select Button Tap or Button Hold
