Changing the Text Language on an Automotive Device if you can't Read it
You can change the text language if a device is in a language you cannot read (wrong language).
This Video is a Quick and Easy way to Learn about Changing the Text Language.
To Change the Text Language:
When the device is first powered on an agreement screen will appear briefly. Select the button at the bottom.
If the device is in Camper/RV or Truck profile mode you may need to select the vehicle profile.
1. Touch the Wrench icon in the lower right of the main screen
2. Touch the down arrow
3. Touch the Lips icon
4. Touch the second option from the top
5. Touch the up or down arrow until you find the desired language
6. Select a language and touch Save
- Save is the button on the right
The device should now be in the selected text language.
