What is the Difference Between the Index Smart Scale and the Index S2 Smart Scale?
The Index™  Smart Scale and Index S2 Smart Scale  share many features including the following:
  • Upload Body Composition Data via Wi-Fi to the Garmin Connect™ platform
  • Tracks Body Composition Metrics:
    • Weight
    • BMI
    • Body Fat Percentage
    • Skeletal Muscle Mass
    • Body Water Percentage
  • Adding up to 16 Users to the Scale
  • Supports Multiple Daily Weigh-ins
  • User Replaceable Batteries
  • Two Color Options
Additional features found on the  Index S2 Smart Scale include:
  • Weight Trend Widget
    • You can see how your weight has changed in the last 30 days.
  • Weight Only Option
    • Disable the body composition metrics, if preferred.
  • Weather Widget
    • When enabled, shows current temperature, high/low, and weather conditions via Wi-Fi.
  • Customizable Widget Loop
    • Only see widgets you want to see on the scale during weigh in. Customizable in the Garmin Connect app.
  • Color Display
Additional details on these features can be found in the owner's manual as well as the following video:
Getting Started with the Garmin S2 Smart Scale:
