The Time on My vivoactive Is Not Correct
A vivoactive displays the time that is shown on your paired smartphone with the Garmin Connect app or from a personal computer using Garmin Express. If the time on your watch is not correct after you have completed a sync with either of these programs, this would indicate that the time setting on the watch is set to Manual instead of Auto.
Set Time to Auto:
  1. Select the Action key (right side).
  2. Select Settings.
  3. Select System.
  4. Select Clock.
  5. Select Set Local Time.
  6. Select Mobile Device (auto).
  7. Sync the device to save changes.
If the time is still not correct after syncing to Auto, you will need to acquire GPS by starting a timed activity. For details please see Acquiring Satellite Signals.
Related
