Setting the Temperature Format on an Index S2 Smart Scale
4It is possible to change the temperature units manually on the scale by following the steps below.
Remove a battery.
Press and hold the reset button and re-insert the battery.
Tap the reset button until you see a screen with an F | C shown on the screen.
The one that is currently set will be bolded.
Hold the reset button on this screen to switch from one unit to the other.
Allow the unit to turn itself off.
When the device is activated again, it will display the temperature in the units selected F (for Fahrenheit or C for Celsius).
