How to Change the Language on the Alpha 200 or Alpha 200i Handheld
If your Alpha® 200 or Alpha® 200i handheld was mistakenly put into another language either by yourself or another user, you can change the language by following the steps outlined below.
Changing Language on the Alpha Handheld
  1. Power on the Alpha handheld
  2. From the home screen, tap the Setup icon
    • It is on the third menu page. It looks like a wrench and screwdriver icon.
  3. Tap System
    • You have to scroll down and tap the icon that looks like two gears together.
  4. Tap Language
    • Language is the second menu field down.
  5. Select desired language
    • English should be always at the top, you may have to scroll up to see English.
