Sharing Routes/Trips from a zumo 396 with Other zumo Users
You can share a route/trip you have created with another zumo user two ways: from a track log, or from a saved route.
To create a trip to share from a track log on your zumo:
1. Touch Apps
2. Touch Tracks
3. Touch the Saved Track
4. Touch the wrench icon
5. Touch Convert to Trip
6. Touch the preferred trip direction
7. Name the trip and touch Done
The track log will now appear in Trip Planner as a trip. To share the trip, proceed to the following steps.
To share a saved trip on your zumo using a memory card:
1. If saving the trip to a memory card, insert the microSD card into the zumo
2. Touch Apps
3. Touch Share Route
4. Touch Memory Card
5. Select the desired route(s) and touch Done
After turning on the receiving device with the SD card inserted, the device should give a prompt to import the route.
To send a trip to another zumo via Bluetooth on your zumo:
1. Enable Bluetooth on both the sending and receiving zumo
    • Routes can only be sent via Bluetooth to another zumo 395, 590, 595, or zumo XT
2. Touch Apps
4. Touch Bluetooth
6. Select the receiving zumo device
7. Touch OK
8. The receiving zumo will display a message to pair the device. Touch Yes
9. A confirmation message will appear. Touch OK
The trip will now be found in Trip Planner on the receiving zumo.
To send a trip to another zumo via Smartphone Link on your zumo:
1. Enable Bluetooth on the sending zumo
2. Touch Apps
4. Touch Smartphone Link
6. Touch Share File in the Garmin Smartphone Link App
    • You can use the sharing options on your phone to send the trip to another zumo user via email
    • Note: Sharing steps and screens may appear differently on various phone operating systems
7. The receiving zumo user can then open the file with the Garmin Smarphone Link App
8. Touch Send to zumo in Garmin Smartphone Link App
