Using Carpet Risers With The Index Smart Scale
The Index Smart Scale comes packaged with 4 carpet feet (risers). If you plan to use your scale on a carpeted floor, it is recommended that you install the carpet risers. The risers will help to elevate the scale above the carpet. If the bottom of the scale is resting on the carpet you may receive an incorrect body composition measurement.
NOTE: The risers should be removed when using the device on a hard floor.
