Changing Data Screens on My Forerunner From My Garmin Connect App
On select Forerunner® watches, you can change the data fields of your activity profiles through the Garmin Connect™ app.
Compatible Watches
Forerunner 165 | Forerunner 165 Music
Forerunner 255 | Forerunner 255S | Forerunner 255 Music | Forerunner 255S Music
Forerunner 265 | Forerunner 265S
Forerunner 955 | Forerunner 955 Solar
Forerunner 965
Steps in the Garmin Connect App
Open the Garmin Connect app.
Access the menu by selecting More (bottom right).
Select Garmin Devices.
Select your device.
Select Activities & Apps.
Select the activity you want to customize.
Select Data Screens.
From this screen you have multiple options.
Add a Data Screen
If you select the Add Data Screen option you can select what type of data screen you want to add to the current rotation of screens.
Edit the Order and Remove Screens
If you select Edit in the top right corner you will be able to remove and re-order the current list of screens that will show in that activity.
Select a Screen to Edit
If you select one of the screens that are currently listed you will be able to edit the layout and displayed data fields.
