Must Sync Clock with GPS Message When Accessing the Deezer App
Why does my watch need a GPS signal to use the Deezer Music app?
Your watch requires an accurate date and time to run the Deezer music app. It gets this information from a GPS signal. You will typically only need to do this when the watch is new or if the battery has been fully drained.
How to Sync Your Watch's Time via GPS
Go outside to a location with a clear, open view of the sky.
Select an outdoor activity from the activity list (e.g., Run, Walk, or Bike).
Wait a moment for the watch to acquire a GPS signal. You'll know it's ready when you see a message like "GPS Ready," a green ring, or the watch vibrates.
Once the signal is acquired, you can return to the main screen. The Deezer Music app will now be available.
