Xero X1i Crossbow Scope Yard Stick
On the Xero® X1i Crossbow Scope there is a setting to display the size of a yard stick at the ranged distance. This is helpful if you are trying to measure a target at distance you can have the yard stick measurement displayed to allow you to measure your target. To turn Yard Stick on
- From the Hunt Display Press OK.
- Highlight the gear Icon
and press OK.
- Highlight Pro Settings and press OK.
- Highlight Yard Stick and press OK to toggle on.
- Select Back until you are back to the Hunt display.
With Yard Stick turned on.
- Take a range.
- Tap the trigger until you see the vertical and horizontal measurements.
Note: If fixed pins are setup giving the trigger a tap will first display the fixed pins, giving the trigger a second tap will display the measurement lines.
